It is currently Thu Aug 21, 2025 1:04 pm
 Post subject: bending tiger wood
PostPosted: Fri Oct 25, 2013 1:21 am
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
A friend of mine and my self tried bending tiger myrtle wood with no luck at all. Process was a fox style bender layered from the bottom up: steel, aluminum foil, wood, aluminum foil steel, heat blanket at about 300 for about 5 to 10 minutes before bending the cut away. It broke both times at the cut away. I soaked in fabric softener for about 1/2 an hour. Wood was .080 so i don't think it was the thickness, pretty much quarter sawn as well. Any ideas?
Blake.
Blake Dixon
Kelowna B.C.
 Post subject: Re: bending tiger wood
PostPosted: Fri Oct 25, 2013 6:14 am
State: Tennessee
Blake.
Sounds like you over cooked it, 300 degrees is 300 degrees no point in waiting 10 minutes, to bend.
PostPosted: Fri Oct 25, 2013 7:32 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Blake I/ve bent myrtle for a Cl. the sides were old .I used vy little water just a light mist and started bending at 250 deg f on an overholtzer cl alum bending form.which heats up vy slowly. I worked at it vy slowly took abt 1ominute per side.
PostPosted: Fri Oct 25, 2013 8:35 am
First name: Chuck
Last Name: Gilbert
City: Magnolia
Zip/Postal Code: 77355
I'd say that 5 - 10 minutes at 300 degrees dried it out. I've found that there's no point in letting it sit at any particular temperature, just start bending when the temp gets to about 220 or so - when you see steam - and go slowly.
Chuck
PostPosted: Fri Oct 25, 2013 9:23 am
I made this video about a year ago. It wasn't meant to be informational, but I do note the routine, and you can see how easily the tiger myrtle bends. What isn't noted is that I let it sit around 300 for about 20 minutes to set the bend.
Bending Sides
PostPosted: Fri Oct 25, 2013 10:26 am
First name: Danny
Last Name: Vincent
Ask his ex. I think she had him bent over pretty well.
PostPosted: Fri Oct 25, 2013 1:03 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
laughing6-hehe Took me a minute! laughing6-hehe
Alex
PostPosted: Fri Oct 25, 2013 1:58 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Blake;
did you try to make the bend quickly?
I always bend every side & especially cutaways
very slowly.
If I feel any resistance I stop!
let the wood get more heat & the fibers set to
go again.
Mike Collins
PostPosted: Sat Oct 26, 2013 12:46 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Thanks so much for your help however my problem bend is the cut away. After the bend. The cut away is cracked. All the other bends are good. Any ideas about concentrating on the cut away bend?
Blake
Blake Dixon
Kelowna B.C.
PostPosted: Sat Oct 26, 2013 1:40 pm
Can you post a pic of the crack? The nature of the crack can be pretty revealing.
PostPosted: Sat Oct 26, 2013 3:02 pm
First name: Danny
Last Name: Vincent
wow7-eyes eek wow7-eyes eek I'm not sure Lance is going to like the direction this is going.
PostPosted: Sat Oct 26, 2013 4:15 pm
First name: Blake
Last Name: Dixon
City: Kelowna
K will do next week I'm away right now I will post the photos and let you guys decide what I did wrong
Blake Dixon
Kelowna B.C.
PostPosted: Sat Oct 26, 2013 10:43 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
For cutaways or even non-dreadnaught sides, you want to thin the side down to no more than .07" or .065". It doesn't seem like much but the extra few thou of thickness really reduces stiffness by quite a lot and can solve most bending problem.
Typhoon Guitars
PostPosted: Sun Oct 27, 2013 12:43 am
First name: Blake
Last Name: Dixon
City: Kelowna
So .08 is to thick?
Blake Dixon
Kelowna B.C.
PostPosted: Sun Oct 27, 2013 12:46 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It's too thick for cutaways. Even Robbie O Brien recommends thinning to .065" for cutaways and that's for an easy wood like Indian Rosewood.
Typhoon Guitars
PostPosted: Sun Oct 27, 2013 12:52 am
First name: Blake
Last Name: Dixon
City: Kelowna
K will do I'll take it down to just over .65 thanks
Blake
Blake Dixon
Kelowna B.C.
PostPosted: Sun Oct 27, 2013 2:07 pm
Last Name: Collins
City: Argyle
State: New York
Is this a crack that follows the grain of the wood?
Or a fracture that goes cross grain?
Mike Collins
PostPosted: Sun Oct 27, 2013 3:19 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Fracture across the grain almost a if it was bent to cold.
Blake Dixon
Kelowna B.C.
Users browsing this forum: CarlD and 16 guests
